Need Help Please!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86jimbo, Oct 28, 2005.
  1. 86jimbo
    86jimbo Registered Member
    Sep 8, 2005
    59
    Arkansas
    I Have A 86 Jimmy That I Just Put A Dana 60/14bff With Disc Brakes In. My Master Cylinder Dont Like It. I Cant Find A Master Cylinder That Will Push Enough Fluid For 4 Wheel Disc To Stop This Monster. Please Help!!! Im Leaving For A Event Today, And Id Like To Run My Blazer.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    mine had no issues with the swap. It would lock up the stock rear drums with little effort. When i switched to the disks in the rear it was still a little touchy so i now run an adj. prop valve in the rear.
    Is you MC still good?
    Have you changed the stock prop valve?
  3. 86jimbo
    Sep 8, 2005
    59
    Arkansas
    I Was Told That I Didnt Need To Change The Prop Valve. I Have Used Many Diff Types Of Mc, Even A New Stock One
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Try making a piece of brake line to bypass the prop. valve just to see if it gives you more stopping power. It may lock them up, but atleast you will know if you need to put in an adjustable prop. valve
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I converted mine to disc. It seemed to brake fine until one day when I hit the brakes a little quick while flying down the highway. The rear locked up and it was pretty interesting for a few seconds. You might say the pucker factor hit an all-time high.... :eek1: I'm going to put the valve in the rear line and run a guage to each caliper just so I don't neet to worry about it again.
