Need Help Popping in Rear End
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jun 28, 2001.
    Need some help on my rear end. I was coming home tonight and when I put it into reverse to back out of a parking spot I turned the wheels and my rear end start popping and grinding. Turn the wheels straight and there is no sound what so ever. I continued on home about 20 miles and nothing. I then turn into my driveway and I heard it again so I backed up and it almost sounds like it is binding up, cracking and popping. It is a 10 bolt rear end with 33" tires and 4 inch lift. The strange thing is going straight sounds normal forward or reverse. It is to late to get under it tonight, I am glad I have another vehicle to drive tomorrow. Any suggestions would greatly be appreciated?
    larryboz86k5
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    hmmmmm, first thing i would do would be to check both the u-joints in the rear and the u-bolts as well, maybe they are loose and when they are torqued (sp?) during a turn they could be popping...good luck!
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    We need more info. Posi, gov lock, other locker, open?
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Take the cover off. If you find any metal suprises, you'll defintely know what's up.
    Tim
  4. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    the same thing happened to me with my old bronco. I'm betting that it's the spider gears. Let me know if I'm right.
  5. It has 3.42 gears in it and the guy I bought it from said the rear end went on him and he had an Auburn posi put in it and I have had it for 2 years now. I have a feeling I will be on the lookout for a 14 bolt.
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Mines popped ever since I had the possi put in when I turn and back up...... Had it apaart a couple of times to check and everything looks great inside....mine is a 12 bolt.... We'll see in another year........
    C'moe
    <font color=black>the blazer is "Back in Black"
  7. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I lost a couple teeth off of the ring gear a couple years ago. The only time it made any noise was when I turned right.
    That's because I'm the devil.
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    My gov lock in my 12 bolt locked up cause there wasn't enough fluid. So I took the cover off to make sure nothing was broken and filled it up and it's fine. There wasn't any popping. Just tires chirping like I had a locker. Anywho, I agree, we need more info on what you're running in your diff. Also, just taking the cover off and looking will provide you and us with more info as to whats wrong.
    <font color=blue>I've got a mind like a . . . a . . . what's that thing called?</font color=blue>
  9. It has never done this before. I am at work and will take the cover off this weekend and check it out. As far as what is inside it has 3.42 gears, Auburn Posi, 28 Spline axles What else do you want to know or I will just post when I get the cover off of what I see, I will take a pick also.
    Larry
