need help, problem with brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cyborg50, Apr 26, 2002.
  1. cyborg50
    cyborg50 Registered Member
    Dec 17, 2001
    5
    Poland
    hi.
    I own 86 burbon with hydro bost.
    My breaks don't operate well after they going hot.
    It looks like breake pedal don't return to his off position.
    It returns slowly and the brakes operates when i start to drive. If i push the pedal up with my foot the brakes stop braking immediately.
    I suspect hydroboost unit or maybe brake master cylinder.
    What do you think??
    If hydro boost became to have malfunctions, i considering switch to normal vacum operating brakes. (i drive on gas now)
    But i discover that two different power brake unit are:
    w/JB7 and w/JB5. What is the difference? With one is for me? I suspect that if my car is equipt with hydrobost jd5 - jb5 should work fine, if jd7 - jb7 woul be ok. But how to recognize what hydroboost system is instaled in my car??
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    My .02, don't scrap the hydraboost; it's a good unit. Yes it sounds like your booster is going bad. Mine started applying (dragging) the brakes this past winter @ 150K. I had access to another used unit so I just swapped out the booster, didn't even have to crack a brake line (Hey it's cold outside!).
    I've heard there is a rebuild kit for the booster build I've never dealt with one. I started to open my old (bad) one up but I could see any obvious failure. I never heard of jd5 or jd7, but I do know there is a difference between K5 (M1009) and K30 (M1008). It's been awhile but I remember to tell the difference look at the accuator shaft. I "think" K30 have a 45' chamfer on the shaft, while K5s have no chamfer or 90' groove/chamfer. (Or this could be backwards).
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    <blockquote><font class="small">In reply to:</font><hr>
    Hi.
    I own 86 suburban with hydro boost.
    My breaks don't operate well after they get hot.
    It looks like the break pedal won't return to it's at-rest position, It returns slowly.
    The brakes operate when I start to drive. If i push the pedal up with my foot the brakes stop braking immediately.
    I suspect hydroboost unit or maybe the brake master cylinder.
    What do you think??
    If hydro boost is the malfunction, I'am considering switching to normal vacum operating brakes. (I have a gas engine, now)
    But I discovered that two different power brake units are avalibe:
    w/JB7 and w/JB5. What is the difference? Which one is for me? I suspect that if my Suburban is equipt with hydrobost jd5 - jb5 should work fine, if jd7 - jb7 woul be ok. But how do I recognize what hydroboost system is installed in my Suburban??
    <hr></blockquote>
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    <hr></blockquote>
    This could be normal, Brakes will fade when they get hot, but it would take alot of heat to do that.
    Are the brakes draging? This could cause the brakes to over-heat and fade.
    <hr></blockquote>
    Hydro-boost systems tend to have a slow return to at-rest position. All-though, if it is very-slow to return, than you might have a problem. It could be the fluid return circut in the master cylinder, or the booster system. I'm not sure which could be your problem, if that is the case..
    <hr></blockquote>
    Look inside your glove box, there should be a production label that will have "JB5" or "JB7" onit.
