need help quick! forgot how to tell ratio when truck is off ground
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Oct 28, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    just bought a 69, i have it up off the ground and the wheels are off, i forgot how to tell the ratio by spinning the hub and watching the drive shaft, or do i have it backwards? thx--j.c.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    spin the tire one complete turn and count how many times the drive line turns if it turns 3 and 3/4 turns you would have 3:73's 4 and a quarter turns =4:10's hope this helps
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  3. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    thats what i thought too, but that's not right, i spun the drum i complete turn and the shaft went 1-3/4 turns, the truck orig. was a 6cyl. so i know its got atleast 3:73's or 4:10's, it shifts into 3rd gear at 30mph! thx j.c.
  4. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    If the diff is non-posi then you need someone to hold the other wheel...or just jack up 1 side.Since you just got it,pull the rear cover and get the numbers.It wouldn't hurt to check the condition for the sake of a few dollars in gear oil.Just my opinion.
    chevrules...always has and always will
  5. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    thx ill go try that.
  6. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    Re: need help quick! forgot how to tell ratio when truck is off ground *DELETED*
    Post deleted by flblazer
  7. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    had the other side held still and spun the drum 1 complete turn and the shaft went around 1-3/4 times, what the hell?
  8. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    what the f#@k are you talking about ive never owned a f#@d, you must have the wrong guy!
  9. flblazer
    Nov 24, 2000
    149
    tampa fl
    what the helll youSAYIN i never said anything about a ford
    when will you learn you need a chevy to wheel then a foR% stilln pissin on that ford
  10. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    ok,---- have another one!!!
  11. flblazer
    Nov 24, 2000
    149
    tampa fl
    i think you need a drink by the way you have 273 gears
    when will you learn you needto drive a a chevy an pull fords out of the mud or over themsame as a jeep some one move that ford b 4 i go over it
  12. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    1 3/4 + 1 3/4= 3.5...not 2.73's. They could be 3.73's.
    Pull the cover and be sure...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  13. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    yes they are 3:73's whisch im sure will suck w/the 35's im about to bolt on! thx--j.c.
  14. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    dont worry i had 3.08's with 35's before upgrading to 4.56 BOY can you tell the diffrence! I had no pull in 2nd or 3rd gear!Now i can gun it in 3rd gear and have alot of pull and power.
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    next... off with the cat's and a single inlet dual outlet flowmaster with 4" tips =D
  15. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    It requires two revolutions of the tire.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  16. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Put the tires and wheels back on. Mark the tire, and driveshaft, roll the truck, count the driveshaft turns.
    It can not be done by lifting a tire(s) unless you know(FACT) what type of diff.(Posi, locker,Open....) is
    in the axle.
    Good luck
  17. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    This issue has been cussed and discussed at length previously. Based upon what you have said previoulsy, please explain the following to me:
    I tried this method on three axles all sitting side by side, off the ground, not on vehicles. A 14B w/4.56 gears and Detroit Locker, D60, 4.56 gears open, and a 12B, 3.73 gears w/Auburn posi. Two complete revolutions of the drums on the 14 got aprox 4.5 turns of the yoke, same for the D60, and 3 3/4 on the 12B. Looks like it works to me.
    Derf00
  18. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    The 14 bolt should have turned the driveshaft 4.56 times to one turn of the drums, with both drums turning the same direction. Have you verified the Detroit?
    Rene
  19. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Okay quick draw! I was hoping Mr. Exe would answer and catch what I said, but you beat him to it. Of course you are right.
    Derf00
  20. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    Yer a tricky guy Fred...for a second I thought you might have got duped out of a Detroit...or you had 2.25 gears[​IMG]
    Rene
