need help quickley, please
Discussion in 'The Garage' started by surpip, Jul 31, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    /forums/images/graemlins/1zhelp.gifi got the 14ff all lined up anny good tips on setting the pinion angle? do i need to do it at ride hight?
    kinda scared never done this before and i dont want to screw it up, i would like to get it right the first time!! thanks alot,
    dale /forums/images/graemlins/1zhelp.gif
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Re: need help quickley
    You should set the pinion angle with everything the way it will be when going down the road. I take it you moved spring perches and are putting on new ones?
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yes anny tricks to do it with out the angle finder?
    i couldent find a good one
  4. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I just did the same thing. I sat everything in place, with the weight of the K5 on it, and used a straight edge to line up the angle by eye. I set it up for a CV shaft though, so it wasn't too hard.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya my truck has a cv shaft on the back of the tail shaft to so that means it isent as critical?
