need help, rather fast.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stevewix, Dec 22, 2004.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    ok, i broke a slip yoke last weekend on my '85 cucv blazer, what is the output shaft diameter/outer diameter of the slip yoke/number of splines?
    i can't seem to have any luck, ideas on a part number? also, can i get a slip yoke with a 1350 u-joint that will fit the stock t-case?
    i've got a team of guys coming over tonight to knock this project out in a few hours (1 ton axle swap) and i'd like to be prepared.
    here's my parts list so far:
    u bolts f/r
    spring perches (rear)
    1310/1350 conversion ujoint
    your help is appreciated! i MUST find this slip yoke in the next few hours.
    thanks in advance...
  2. stevewix
    Dec 2, 2004
    83
    ok, found some info. it has a seal surface of 1 7/8". now i need the output shaft diameter/# of splines/ and slip yoke length.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    probely just order 1 for a 1ton with a 208 and slipyoke that is a 1350 most of the time
