Need help, rear end noise!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Oct 27, 2001.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Help, I just bought my Blazer and the 10 bolt in the rear is making noise. It only does it when Im on the gas, when its coasting it goes away. My friend thinks its the pinion bearing. Any one out there had this same problem before?
  2. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    Mine did the same thing on my '91 10 bolt rear. Made a horrible screaching type of sound under acceleration, it was the pinion bearing.
  3. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    take the cover off an see if every thing looks good mine was doin it to your friends is right
    when will you learn you need a chevy to wheel then a foR% stilln pissin on that ford
  4. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Right now I dont have a shop and this thing is still under warranty, do you know how long it would take to swap the bearing?
  5. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    I had mine replaced by a shop, and it took them about 6 hours or so I beleive to do it, but I also had them put new seals and bearings in the entire rear end. If it's under warranty, call whoever you bought it from and make an appointment to have it fixed.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah, its the pinion bearing...mine did that just before it went out.
    90K5
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    It could be alot of different things, but to make sure it is the rear I would pull off the driveshaft and check the u-jt's. If they are ok check the diff fluid in both the diff and the tcase. Make sure they are full. Next I would pull the rear diff cover and look for metal, teeth, etc.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
