Need Help rear end !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Aug 9, 2003.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    I have a 86 K5 Blazer. my 10 bolt rearend blew up which had 4.56 gears in it to turn my 35 inch tires.
    I have a 700-R4 tranny. My question is what rear end can I put in there that is stronger than a ten bolt. What type of truck should i get the rear end from and what year also what needs to be changed. /forums/images/graemlins/angryfire.gif
  2. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    chech out the post about boring a d44 to make it a dana 60, custom 10 and 12 bolts are also being duscussed in this thread /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    14FF from any 3/4ton rig....but the only way your going to find a 14FF WITH 4.56's is a military rig, unless you get lucky and someone is selling one with the gears you want in it already. Only other thing you'll need is a conversion u-joint /forums/images/graemlins/thumb.gif
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    PM "WAYNE" He is on a trail run this weekend but he has 14BFF rears with 4:56's for sale. I'm getting one from him this month along with mt D60. He lives in PA so it's sort of close to ya
    Bryan
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]There are plenty of 3/4 & 1 tons that came with 4.56's that are civilian vehicles and aren't real hard to find. I even found a 14BFF with 5.13's that were factory.
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14 welds,406SBC/700r4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  6. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Monster,
    The 14 Bolt Full Floater from a 3/4 ton will bolt right in, assuming your rig is of the 73 to 91 vintage. The 1 ton version will need to have the spring perches and shock mounts relocated. Stick with a 3/4 ton. Hopefully you'll find one with 4.56. If not, it might be a good time for that posi along with the new gears!
    Expect to pay $100 to $200 for a complete 14 Bolt FF w/ open dif.
    Good Luck,
    Eric M.
  7. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Wow, that's cheap. It'd cost more for me to change the gears in my 12-bolt. Is this a functioning unit, or a rusty heap from a junkyard?
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    At the least, $200 should get you a 14FF in decent(running) shape with a posi and 4.10's or lower. I paid $400 for a front 3/4ton 10b in very good condition, good R&P,bearings,seals and a 14bFF W/posi,4.10's, and 70% brakes left. 14BFF's that have high ratios like 3.73 and higher are worth about as much change that is in your pocket in an used condition. /forums/images/graemlins/tongue.gif
    85k5,3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  9. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    If you are going to replace a rear 10 bolt (6 lug) with the above recommended 8 lugs, you will also have to get 8 lug wheels /forums/images/graemlins/frown.gif
    A 12 bolt is stronger than the 10. Easy to find and cheap as well.
    [I could be wrong]
    You can get a 14sf from a 70's/80's rig, then go get some 6 lug axles out of a late 80's/90's 14sf and swap them. Maybe the backing plates too. This way you could stay 6 lug and run a much stronger rear.
    [/I could be wrong]
    Good luck
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would agree, this would be a good upgrade for a vehicle on the border of being past the limits of the rearend. If you find an 80's-90's 14sf use that don't look for an older one. I was told by a mechanic that a 14sf born with 8 lug axles cant be converted to 6 lug but I have a hard time believing that /forums/images/graemlins/rolleyes.gif Still the 14FF has it's advantages over the semi floater and should strongly be weighed in. /forums/images/graemlins/thinking.gif
