Need help regarding door interchangability
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Jun 13, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Are the front doors off a second generation crew cab the same as the doors on a standard cab?
    More specifically, will a pair of front doors off a 79 crew cab fit my 87 standard cab?
    Thanks,
    Eric M.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i believe so...
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the front doors are standard across pickups, K5's and Suburbans of the same body style. The back doors from a crew cab will also interchange with the back doors from a Suburban of the same body style. /forums/images/graemlins/cool.gif GM is the master of using parts for more than a single application. /forums/images/graemlins/thumb.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There were however several changes in the vent window over the years. If you have complete doors it is no problem, but if you need to reuse your vent window assemblies then you need to check years first.
