need help removing fuse box
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by asterix, Oct 9, 2004.
  1. asterix
    asterix Registered Member
    Jan 9, 2004
    96
    Broomfield, CO
    Not sure if this is a skock wiring but the radio no longer works sence i pulled out the parking break pedal. the wire for teh radio i bet got pulled but it for some reason located behind the fusebox. i've searched and looked through all my books and cannot see how it is connected in there..
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    to remove the fuse block there is a screw in the middle of it, unscrew it and the box will come off in side the cab, the other side is held on by 4 bolts
