Need help removing rotor questionsss
Discussion in 'The Garage' started by bigboy, Dec 16, 2005.
  1. bigboy
    bigboy Registered Member
    Nov 8, 2005
    51
    Lafayette, IN
    How to do I get the rotor off and back on I need to change the rotors on both sides and I do not know how they come of like getting the hub and **** off.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    If you've never done it, you'd be wise to purchase the $10 Chilton or Haynes manual, they outline this procedure fairly well.
    Generally speaking it's something like this:
    Remove wheel, remove auto or manual hub, remove lock ring tang, use special 4wd socket avail at any auto store to remove lock ring (or rings if there's no tang), pull outer hub/rotor assembly off.
    Very generally speaking, there lots of little stuff here.
  3. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    Remove the locking hub cover and locate the lock ring that locks the hub into place. Remove the lock and the snap ring on the shaft. Slide the hub assembly out. Using a 4 wd socket (4 point for 1/2 ton or 6 point for 3/4, 1 ton) remove the first nut. Pull the locking washer out and then remove the next nut with the same socket. After removing the second nut, the hub and rotor should pull off. Do a search for installation
  4. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    K if its 4x4 and you need to replace the rotors, do as the others said to get the hub/rotor assembly off then you need to press the wheel studs out in order to separate the hub and the rotor. if you need more info i'll be glad to elabirate. just let me/ us know
  5. bigboy
    Nov 8, 2005
    51
    Lafayette, IN
    Thinks guys I got it off. I did not see the other lock ring thats why it would not come off.
