need help replacing u-joints - fast!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by creampuff90k5, Feb 26, 2003.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    Well, as luck would have it, one of my rear driveshaft u-joints decided to crap out while I'm on a trip about three hours from home...
    For peace of mind, I'd like to replace it before heading back tomorrow, but do I need a vise to do this? I seem to remember reading some other posts about guys changing them on the trail or roadside. What's the deal? I have the sockets to pound out and recieve the caps, as well as a big hammer. Will that do on the ground somehow??
    Thanks in advance.
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    that will work just fine, are you near an auto zone or vip? they rent ball joint press's that work great for u joints.
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    all you need to change a ujoint is a hammer, socket, and a pair of pliers. I have a vise at home and I NEVER use it for ujoints. Once a driveshaft is out I can swap a joint in probably less than 3 minutes. I tried one of those Ujoint tools once and that thing sucked. Just use a hammer.
  4. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Hey, got it!!! Using an old socket, a BFH, and a pair of vise grips, both u-joints are out. The only local auto parts store is a pep girls and not only is almost every loaner tool either lost or missing, they sold me the wrong freakin' u-joints. I don't think these guys even know what a u-joint IS. Don't you hate ignorant counter help?!? Anyway, gotta get a ride back there from a buddy and hope I can make a match within their inventory...
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I'm not sure about your year K5 but mine still had the factory U-joints and they had the plastic Plug thing that is a real PITA if you don't have a press. But if your joints have been changed you mite not have a problem and can change them by using the socket and hammer.
    Eric
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I got to disagree:
    I have done the hammer and socket thing and it works, then I got a regular C clamp and it made life easier, now I have the Harbour Freight Universal C clamp (U joint, ball joint,.. ) tool and it make it easier than a press because you can do it on the truck and it's beefy and it works.
    Now I have it with me all the time.
  7. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Well, the hammer and socket method worked this time - no problem. Everything is back together and ready for the return trip tomorrow without vibration and worry of the driveshaft flying out and bashing everything underneath. Finally found u-joints that fit at the local pep girls, although there was no choice of brands. These from PTC (power train components) and have "heavy duty" stamped on 'em. Hopefully I won't have to do this again for a while... Thanks all.
  8. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    yeah....the plastic plugs in my stock u-joints took 3.5 tons of pressure on a hydraulic press before they gave up. total PITA. good thing to replace those u-joints before they break on the trail with traditional ones that can be removed without a press.
  9. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    If you have the factory u-joints with the plastic plugs, just get a torch and melt the plastic. They'll come out with a vise. No press needed. /forums/images/graemlins/grin.gif
