Need Help setting up rear axle
Discussion in 'The Garage' started by conoverbandit, Sep 9, 2003.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Hello,
    Anyone with axle experince around here? My dad's got a 87 K-10 swb The 10 bolt blew the ring and pinion about 4 weeks ago,we bought all new stuff again,Ring and pinion, came with inner bearings and crush collar,shims,bolts ect. We also got the outter seals and bearings.The fella I was going to have set it up fer me said it would be at least a week or longer before he could even check it out, then maybe a week or so to build it.Can anyone tell me what tools i would need to do this?? The guy at 4Xheaven said i'd need a "dial indicator",I've called my local napa,advance,autozone ect. half don't even know what I'm talking about the other half don't know where to get one.Would a chilton's book help?Pop needs to get this thing back on the road asap cause this is his mower towing truck and it's been down for a while now.Any advise,help,ideas greatly appreciated,Thanks for your time,
    Conoverbandit
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
  3. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
    Thanks, we done got the ring and pinion, and all seals,bearings, everything needed to go back stock with this axle, as a side note we did buy a set of axles from another truck, installed the rear one drove it and it has a bent axle, you can see the wheel wobble in the mirror! so we thought we'd get the stock 10 bolt re-built and put the thing back in. /forums/images/graemlins/rolleyes.gif
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    check out randys ring and pinion ringpinion.com .look in the technical section and find ring and pinion install.it has a whole i think 13 page sectionon what you need and specifications of axles.on a side note,whats up with the rollbar u had.are you still gonna keep it?
  5. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
    I put it in my truck this weekend........as a side note, I did buy me a pipe bender so hopefully soon I can get me one built like I want andd get rid of this one.Thanks for the info.
    Conoverbandit
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You need a bearing puller, for both the carrier and axle, press, brass punch, dial indicator, a setup bearing helps, and whatever to put in the new races. Dont forget to mark the caps and dont mix up the shims. Hope this helps! /forums/images/graemlins/thumb.gif
