Need help - Should I buy these?
Discussion in 'The Garage' started by K30Blazer, Jul 28, 2006.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I have an opportunity to buy a D60 and 14BFF from a friend of a friend for $800. I currently have stock 10b on my truck with 35's. I have a dream one day of building my truck up, moving to 38's and axles etc but I am wondering if this is a killer deal or not.
    How much will I be looking at to rebuild these axles and lock and posi them. I think they are 4.10's as they came off a 3/4 ton.
    I haven't seen any deals around for axles despite people saying how cheap they can be found.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    if it's for sure a Dana 60, then it's worth $800. The rear is a bakers dime-a-dozen.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    If it's a 3/4 ton, then it's only a D44. Double check that before you do anything. The rear is very common, and pretty cheap.
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    D60 has bolts built into it for the spring perches, at least by the pumpkin. It also has 4 bolts for the steering arm. Just so he can check....
    If so, and they aren't THRASHED, ie you could un them now but they aren't exactly the right gear/open etc... a D60 around here is $800 easy.
  5. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    thanks, that is something I will definitely check into.
  6. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I got confirmation that it is actually a D60 so I think I am going to go for it. Gonna be a while before I can do anything with them, but I don't think I can pass this up.
  7. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Hell if you dont buy them I will!
  8. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Sounds like a bargain for both. If it's a chev 60 buy them.
