Need help solving a brake light, turn signal problem
Discussion in 'The Garage' started by Derf00, Nov 9, 2003.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have been chasing a problem with my driver's side brake light. If the left turn signal is applied, the brake light won't work while the turn signal is operating, it will even stop the brake light from working when the ignition switch is off. Any suggestions?
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    In GM's infinite wisdom /forums/images/graemlins/rolleyes.gif, the brake light power runs through the turn signal switch. Replace the T/S switch (plastic junk) in the column, and you'll be good to go /forums/images/graemlins/thumb.gif
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    YES,YES,YES...I spent a year chasing that same problem and it was/is the Turn signal switdh in the columm...
  4. romanviii
    romanviii Registered Member
    Oct 31, 2003
    13
    California
    I would definitely look at one more possibility. A bad ground. It happened to me. A bad ground can be like a ghost in the machine...
