NEED HELP! Steering Column!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jan 2, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    How do I re-install the little white plastic jobber that is found under the locking cylinder? Its the thing with the two long metal tabs that stick out the left side...
    PLEASE HELP!!!
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    check out dyeager's site I think he did a complete tear down and write up...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It just slides back into the hole it came out of. That's the switch that closes when the key is in the cylinder, to make the buzzer sound.
  5. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    <a target="_blank" href=http://www.dorianyeager.com/column.html>http://www.dorianyeager.com/column.html</a>
    clicky
    83K5 Silverado
    What was that bump?
  6. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    OK, I have bigger problems now... I was going into the column to replace the turn signal lever, the ignition switch, and the cylinder itself. Now that I have the column down, I noticed that the existing (broken) turn signal wires were just dangling there, not connected to anything. I have searched under the dash, but can't find the correct wires or the connector... Where they went, I have no idea. Does anyone know what I am looking for? My manual shows 4 wires... none of which are anywhere I can find them!
    Any ideas?
    Also, does it make any difference if the truck was trobably a stick originally? I think the auto column was just dropped in right before I bought the truck... Could that be the problem?
  7. dyeager535
    26,975
    Sounds like someone probably didn't want to go through the effort of matching the plugs up, if the wiring was different, or fixing the broken wiring. There should be a plug at the base of the column (actually a few) but the one you want is flat, with about (total guess) 10 wires going into it. The turn signal switches I have dealt with had more than 4 wires, thats for sure. If you have a wrecking yard nearby, you might want to check out one of their columns, tear it down (say, a broken one) and compare the switches/wiring. Manual/Auto shouldn't matter for turn signal switch wiring.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
