Need help stripping the emissions!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by taterblazer, Mar 22, 2001.
  1. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    My blazer is an 88 TBI Idaho blazer. I want to strip most of the polution stuff off and just keep the good stuff; vapor canistor, egr valve and ? There are so many damn hoses and wires to break and fall apart and I haven't a clue what they do. Want to simplify it. Any ideas or suggestions? Thanks!
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I'd dump the A.I.R. pump and the cat, but thats just me. Not sure about the EGR.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Wouldn't losing the AIR pump on a TBI affect the way the computer would read from the oxygen sensor? I'd be really cautious about pulling ANY equipment off of a computer-controlled engine.............
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I agree w/Canmore. Things can get messy when you have the computer controls and fuel injection. And Blazerboy, that is funny....smell my finger...lol
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Hmm, I've though about that. Mine's an '82 so I won't have that problem. I kinda dismissed it because my dad's '89 has the pump gone. Its in the bottom left corner, right? As far as know all the rest of the brains in it are stock. I'll have to a look under the hood to see whats there. I know there are no cats for sure. Outside of that its pretty much stock only with a 4" lift and 33's.....Glad you like the pic [​IMG]
  6. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Thanks for the ideas guys, maybe I should just save up and get the Holly Injection system if it goes bad. I just hate having all that stuff in there.
  7. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    I don't think you'll have trouble with the AIR removed because your oxygen sensor tells the computer how to adjust
    for top efficiency
    all the AIR does is reduce hydrocarbons by injecting fresh air into manifold to help complete combustion after exhaust valve opening to reduce exhaust potency
    mine is carbureted so i had no trouble
    but I did it to my 91 Firbird and had no troubles
    but before I completely removed it I disconnected my AIR pump belt and my Diverter valve too see how she'd run
    and ran like before and had no service engine soon light
    hope this helps
    If it ain't Intimidating / It ain't a Chevy!
  8. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    My 89' TBI 350 doesnt have anything on it. Doesnt look like it was ever there either(except the cat). I know my truck is from Canada. Maybe thats why its not there.Sorry i cant help you, by telling you what you can remove. But mine is gone, and i dont get any trouble codes and the thuck runs perfect.
    One From None
  9. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    If you have an air injection system with fuel injection. When the engine is cold the air from the air injection is routed before the O2 sensor to burn the unburned gasses comming out of the cylinder head and into the exhaust reducing hydrocarbons. At this time the O2 sensor is not in the picture for fuel metering. Its in open loop operation. When the engine gets warm the air from the air injection is routed after the O2 sensor to the cat so that the oxygen can mix (chemical reaction) with the hydrocarbons and NOX (bad gasses) and break it down to CO2 and water.
    As for the original question, If the wiring harness is messed up Painless Wiring can get you an engine harness. I would not take any emissions equipment off a vehicle with fuel injection. 97 times out of 100 you will decrease the performance of your vehicle. If you don't want to go the Holly Projection they also make replacement TBI with HP gains.
  10. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I had an 87 k5 that the Air pump was pulled off of. It ran ok and passed NJ inspection which is insane that it passed. but whoever pulled it off just left the hose that connects to it under the hood and there was always air coming out of it. Ahh that truck was a beater anyway, Im glad I sold it.
    JD
  11. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    Thanks for all the help. Guess what I'm going to do is read up on TBI as much as possible. If I can understand it I can modify it. Any ideas for books or resources would be appreciated. Thanks!
  12. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    You should be able to remove the canister, AIR pump, and cat without any problems. In '87 (the year that my truck's motor and injection came out of), the sticks had smog pumps and the autos did not. I also know our '89 auto Sub has no smog pump. Do not remove the EGR.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
