need help t/c duport rod?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd-10, Feb 20, 2004.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    hello again, the bolt on the trannyy that the suport rod goes to from my t/c broke and i was curious if i where to go without the suport rod if it would effect the tranny or anything else? it is a np241 t/c.thanks for the help..
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i dont have one on my dd/plow truck but is it 80% and there are no adverse affects. the 2wd truck dont have them either /forums/images/graemlins/dunno.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Mine broke too, but i was lucky enough when i did my trans swap yesterday that there was enough thread sticking out to untread it by hand, i ran without for several months, i think as long as you don't do any high speed wheelin, i.e. jumping or harsh hill climbs to "jar" things around it will be ok, it looks to me like just a support type of rod to help stiffen things up. shouldn't be a problem runnin with out it till you can get the bolt out.
  4. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    2wd trucks don't have them because they have to transfer case. From what I heard that rod is suppose to help support the T-Case to prevent the aluminum case from cracking. Why not just replace the bolt? Don't you need that bolt for the transmission bell housing too?
  5. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    If you never off road you should be good without it. But if your truck gets punished at all you may crack your t-case adapter or tranny case by not having it there.
