Need help. + test
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4 Cowboy, Feb 6, 2003.
  1. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    what do i need to do to see if i have a +. i have gone wheelin in it yet cause truck has been in peaces since i got it thanks
  2. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    I'm not sure what + stands for, but if you're asking for a test to see if it has a "posi" diff simply jack the wheels off the ground and rotate on side of the axle by hand. If it has a posi the opposite wheel will turn in the same direction. If it has a non-posi the wheels will turn in opposite directions when one wheel is rotated. Of course this test is to be done with the vehicle in neutral and parking brake off. I know this will work for the rear axle but i'm not sure about the front.--Hope this helps /forums/images/graemlins/thumb.gif
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Most of time that works,but,sometimes a loose clutch type poss or guv loc will act like open diff till it has load against clutches.With hubs locked front is same as rear.Sometimes if brakes are tight the driveshaft will move instead of other wheel. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  4. 4x4 Cowboy
    Dec 7, 2002
    236
    california
    ya sorry i meant posi. thanks ill try that. but i might have those clutches
  5. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    light tem up see if both tires spin its not proff positve but it might help or you could take the diff covers off
