Need Help. To Cold in The Mornings.
Discussion in 'The Garage' started by st08x, Jan 12, 2003.
  1. st08x
    st08x Registered Member
    Oct 17, 2002
    84
    Texas
    I'm having a problem with getting my k5 to run good in the cold weather. Every morning when I start it, it idles high for about 2 min. then it slows down to the point where it is about to die. then i bad out of my driveway, put it in drive, and when i touch the gas it kind of stalls but comes back on, when i finally get going i idle really low and die at most stop lights/signs. BUT...i have recently discover if i start going and slowly press the gas ALL the way to the floor, it will kick up the idle and run smoothly. Why? I don't know? any ways to get around this? is it bad to gas it right out of the driveway in the cold? i have a goodwrench 350 and a edelbrock carb. with the auto choke turn up all the way.
    my K-5
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    you need to back off the choke some and let it warm up longer...i say 5min minimal on mornings at or below freezing, bump your idle up a hair and run a thinner oil....
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I agree, longer warming, and do you have an air cleaner? That will help, especially if it is a closed canister like stock ( ya i know, they are ugly ) but maybe for just the winter. also, are you missing the passenger side little flexy tube going from the exhaust manifold to the air cleaner? that feeds wrm air when its cold and helps cold mornings. Edelbrocks are not cold weather friendly, at least mine have never been.
  4. st08x
    Oct 17, 2002
    84
    Texas
    i've tried to warm it up longer but it just idles really low and drives really choppy.
    my K-5
  5. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    How old is the carb? Almost sounds like an accelerator pump problem in the carb. It becomes way more noticable in the cold.
  6. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    i would say deffinitly check carb i had same problem with edlbrock found it to be top plate of carb was leaking maybe its just a small vacume leak mine gave me trouble at about 40deg or below then when it warmed up it was fine
