need help updating Headlights
Discussion in 'The Garage' started by deek, Feb 10, 2004.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    the ones i have in my 73' just suck. whats a good lamp that would be a direct replacment, but have a better output(higher wattage). what have the rest of you used?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I would get some halogen lights and rewire using relays. The rewire would make a dramatic difference.
    This is the design I came up with for mine. Since this is for a 4 light system, you will need to adjust the diagram for the two light setup.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You could do away with some wiring and the lower relay by just inserting a diode between pin 86 of the low beam relay and pin 86 of the high beam relay. /forums/images/graemlins/thumb.gif
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    this is on my to-do list... i read that a 2 volt drop can reduce in 30 percent loss of light...
  5. wfotyme
    wfotyme Registered Member
    Oct 29, 2002
    17
    Fresno, Ca.
    I solved my lighting problem in my 74 K5 with HELLA 7" headlights. You can get them through J.C. Whitney. $39.99 each. They are almost too bright for the street, but they are D.O.T. approved.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    DP_90K5, I can't reply to PM's so I'll post the answer here for ya:
    You can eliminate the lowest relay in your drawing by inserting a 1-amp diode between the input of the low beam relay and the input of the high beam relay. The cathode (the end with the stripe) connects to the input of the low beam relay. When the high beam relay is on, the diode will be forward biased and will flow current to the input coil of the low beam relay, turning both relays on. Then when the high beam relay switches off and the low beam relay comes on, the diode will be reverse biased and won't pass current back to the input of the high beam relay. So only the low beams will be lit in this mode. /forums/images/graemlins/thumb.gif
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Great, thanks for the information.
    One more question. The diodes I have seen are only 1" or so long. How can I physically connect the two relays using a diode?
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just crimp or solder a length of wire to one end of the diode. /forums/images/graemlins/thumb.gif
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    That's what I needed to know! /forums/images/graemlins/thumb.gif - if you could add wire to a diode...
  10. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    this post is a few weeks old so i thought i would hijack...
    if i want my low beams to stay on when the high beams are switched, do i just eliminate the lowest relay (the one behind the firewall) in dp 90k5's drawing?
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    The drawing is designed to leave the low beams on. The relay that shows to be behind the firewall is the relay that turns the low beams on when the high beams are on(all three relays are actually mounted on the driver's side fenderwell inside the engine bay - that part of the drawing is misleading). The other option is to do what Harry has posted. Just use a diode between the high and low beam relays...
