need help w/driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 454jimmy, Jul 30, 2001.
  1. 454jimmy
    454jimmy Registered Member
    Nov 16, 2000
    8
    Tennessee
    ok I need some help here folks ! I put a 350/203 in my 85 jimmy it had a 700/208 . so i used the drive shaft that came with the 350/203 it was to long so I had it cut when I went to put the drive shaft in the Ujoints were too small for the rear end . what can I do? do they make Ujoints with one side 1 size and the other side a different size? this is all I need to get back out there and play. so any help would be great!
    thanks
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    what type rear are you running? If its a 10 or 12 bolt, you can swap out the yoke to a 1310 size and the d-shaft should fit. If it's a 14 bolt or a D60, you'll need to upgrade the yoke on the 203 (205 yokes will interchange) and get a new d-shaft made.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, get a hybrid/bastard u-joint and no problems.
    Tim
  4. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    Don't need a new yolk. I just swapped a 14FF for my 12 bolt and am using the same driveshaft. It's a 1310/1350 conversion joint. Measure cap diameters, length of each end and retainer type (centering lug, outside circle ring or inside clip). My 1310/1350 conversion cost $25 and boy does it look funky! You should have no problem finding the ride conversion joint.
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Hybrid u-joints are easy to find and are reasonably priced.
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I paid $14.99 for my K20/K10 hybrid joint at Napa - and they had a dozen in stock.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. 454jimmy
    Nov 16, 2000
    8
    Tennessee
    THANKS for the help folks I am off to the parts store now .
