Need help w/ Fiberglass repair:
Discussion in 'The Garage' started by conoverbandit, Feb 2, 2004.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Hey Y'all,
    My 87 dually I just got has a few cracks in each fender, I've never worked "glass" before. Is there a way to repair this or do i need to hunt another set of fenders? Also my truck has a air dam in the front, it has taken some pretty good licks, is it possible to reapit it? I figure the conversion company stopped selling parts for it along time ago so I figure I'll never find a replacement for. Any help greatly appreciated, Thanks
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    If its glass fenders then you need to make a groove where the crack is the full length of the crack plus drill a small hole at the end of the crack to help stop it from cracking further. then you are going to do this layer after layer from bottom side til the crack is covered well and place a couple layers on top, not too much on the outer surface as glass is hard to shape! Use body filler after the repair to smooth out the fender.
    Bill
  3. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
