Need help w/ frozen bolt
Discussion in 'The Garage' started by Bandit175, Aug 11, 2003.
  1. Bandit175
    Bandit175 Registered Member
    Nov 4, 2002
    32
    Savannah GA
    I have a square tube bumper with a swing away tire carrier. The hinge is really just a 8"x1" bolt welded o the actual swingout part and then slid into a hole drilled through the bumper. The thing is totally frozen. I sprayed all kinds of rust cutter and lube on the thing and have tried everything I can think of. Hammered it, heated it and hammered it, pried it with a halligan tool, even tried to push it out with my high lift but just lifted the whole back end off the ground. PLEASE HELP
  2. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Could the problem be that it's bent (and not stuck)?
  3. Bandit175
    Nov 4, 2002
    32
    Savannah GA
    yeah my dad mentioned that it could be bent but it doesn't really look like it though...if it is bent what should I do cut the bolt off and try to hammer it out the bottom?
  4. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    My opiunion is to use some combination of grinder, acetylene torch, and a BFH. Tat should do the trick. If all else fails, give me the title and make it my problem instead! /forums/images/graemlins/usaflag.gif
  5. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I can't envision your exact problem enough to give real good advice. From my recent experience though, I'd suggest thinking in terms of a grinder with a cutoff wheel attachment, and what disposable parts you could grind through or off to solve your problem. /forums/images/graemlins/thumb.gif
