need help what would you do frame cracked
Discussion in 'The Garage' started by mudduck, May 10, 2002.
  1. mudduck
    mudduck 1/2 ton status
    Jun 30, 2001
    245
    wentzville mo
    just started to finish up D 60 swap on my shortbed took factory shock mounts off to put on the ford towers and guess what on both sides behind mount there is a crack in the frame i bought this truck, on the drivers side someone welded it up to shock mount and shock mounts were also welded on guess i should have been more curious when i bought this truck, what would you do get another frame or try to fix this one the truck has a real good body which is why i bought it in the first place, got laid off and had to sell my other projects now this is all i have, thanks for any advice or help,
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    What we do on big rig frames is put another frame inside of the cracked area and about a foot either way and bolt it in.
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Another thing to do, which is similir to what 70 said, is to "fish plate" the crack. Cut some plate steel to fit over the crack on both sides the same width of the frame and extend 6-12" on either side of the crack, Then weld it up. Also, do not weld all the way around the edge of the the plate. It's not really necesary and the excessive heat can weaken things. Just small welds spaced out evenly around the perimeter is all ya need.
