need help with 10 bolt axle
Discussion in 'The Garage' started by icehole, Apr 27, 2002.
  1. icehole
    icehole Registered Member
    Apr 2, 2002
    10
    sterling hgts. MI.
    ok i just rolled my gm 10 bolt axle under the jeep and put the wheels on and they are curved out at the top like this \---/ i put all new ball joints on could i have gotten the wrong ones??? can the spanner nut things be adjusted to correct this?? i have also tried to rotate the axle forward and backward to see if this angle would change, no change...the housing doesnt seem to be bent,what else could it be??????help....
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The first thing I would try is to rotate the spindles. That is how they do alingment at the factory (that or they try another spindle). I always mark mine befor I take them off (left and right as well as rotation....ie: some spray paint). It will be a pain to do but you might be able to match up the rust pattern to see where they were befor you took it apart.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i dont understand, i guess its a jeep thing
  4. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    post some pics and maybe we could help.
    Brian
    82 burb 38.5's, sm465/np205, 10/14bolts
  5. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I had my blazer re-aligned and the tires are tipped out at the top also. I think this is the way is supposed to be. And I also have a 10 bolt.
