Need help with 12v DC air compressor wiring
Discussion in 'The Garage' started by randy88k5, Sep 4, 2006.
  1. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Ok, some background. I purchased ths pump a long time ago. They still have them on ebay
    http://cgi.ebay.com/12v-1-5-gal-air-compressor-Puma-6-50-Ship_W0QQitemZ180022942095QQihZ008QQcategoryZ11751QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    So, about a year ago, I decided to take off the pressure cut off switch and wire the air compressor through a relay, and controlled by a rocker switch in the cab. So, I would leave the regulator plumbed into the air line, and just have the compressor running when I need the air, and just have the excess bleed out into the engine compartment (I have it mounted under the hood [now] with remote air resovoirs [future])
    Well, after I have already wired it to the relay, I am having second thoughts. I am going to use this to supply air for my ARBs mainly, but also to run air tools if needed.
    I was thinking that if I turned the compressor off while offroading locked, and the air bleeds down without my noticing (I have an air gauge easilly seen), the ARBs could unlock while in use, and I dont want that.
    So now, Im thinking about wiring that switch back into the mix, but I want to be able to turn it off electrically with a rocker switch regardless of pressure. So, I took it apart over a year ago, and I dont realy remember how it works. I have pictures...
    In the picture of the regulator portion, I had left a screw loose so I knew what one to reattach it to if I wanted, but I forget if it was the positive or negative wire (the compressor has the customary red/black wires). The screwdriver is pointing to that particular screw.
    I am using the standard 4-pin style box relays. How would one go by wiring this. Thanks for the help guys and sorry for the long read. Just wanted to put the info out there.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Screwdriver is the red/hot/positive post......I think. Ground/negative/black is the one closer to the bow off valve.
    If it's 12VDC, it will run back wards if you connect it back wards. If it does, just swap 'em.
    Don't forget to use a fuse or circuit breaker!
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    How about a photo of it beside something to judge the size of it by. :laugh:
  4. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yeah, I knew it would run backward, just didnt really want it too.
    I cant remember if 1 or 2 wires went into this thing. The 2 smaller screws near the blow-off valve are for setting the cut-on and cut-off pressures. All of the other screws are tight, so I dont think I took anything else off. There is a ground screw near the rubber gromet though, but it weas not loose either.
    Um, I cant find any tape measure right now, but the screwdriver in the picture is the Craftsman precision ones, and the silver part to the tip is exactly 3".
    Yes, it is wired to a fuse right now.
    So, would the relay load wire go to one of those "motor" screws?
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    There should be 2 wires going in/out of the pressure switch.....1 would be a wire going to the pump motor and 1 would be from the power source.
    When I wired in my york, I have a relay in my circuit and a in-cab manual switch.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I was interested in the size of the whole compressor. :wink1:
    Power supply------positive from the manual switch/fuse/CB or the relay
    Ground------------to ground
    Motor-------------to the motor
    You would use the manual switch to turn on the relay that then in turn, turns on the pressure switch, which then turns on the motor.........
  7. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Sorry Dontoe, I misunderstood :doah:
    I borrowed that pic from Ebay
    Heres what you wanted:
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    That's a nice compressor......Hmmmmmmmmmmm.......I need to upgrade!
    My "little" one............
  9. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    Tell me how!..
    How are you going to run that compressor,that on the tag says its 125V AC or 250V AC,on 12 volts??(or is that the pressure switch I'm looking at??--if so,will it work on DC as well??)..using an inverter or generator??...just wondering...:crazy:
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yep, that's his pressure switch.
