Need help with 14 Bolt FF Gov Loc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Oct 31, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm purchasing a 14 Bolt FF with a Gov Loc. The guy has 2 of these.
    Unit #1 - With the pinion held still, if you turn one wheel the other turns in the opposite direction, like an open differential.
    Unit #2 - If you turn one wheel, the other goes the same direction. You can't move one wheel independent of the other. He grabbed one, I grabbed the other and it was like we were trying to twist a spool.
    First question. Is one broken? Which is the proper operation for a Gov Loc?
    Second question. Do Gov Locs wear? What happens when they wear? How can I tell if it's worn out? Can they be rebuilt or is it even worth it? (Sorry, more like 4 questions in 1)
    Third question. I hear bad things about Gov Locs. This one will be behind a stock FI 454 and a Turbo 400. It won't be wheeled hard, mostly snow. Is this thing going to blow up and destroy my housing or will it work for what I'm doing.
    Thanks, and Happy Halloween!
    Eric M.
  2. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Can't help ya with everything thing, but maybe a few. The Gov-lock in my 14bff, with the pinion held still, one wheel spins forward, one spins backwards. Pretty sure this is how they should operate. Unit #1 sounds like the average gov-locked rear end, and unit #2 sounds like it has either been welded or had a spool type locker added.
    Yes Gov-locks wear. They have little clutch packs in them that help enable the locking and unlocking of both tires. Those clutch packs can wear down or wear out over time. Hope that was some help.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    gov locks are as close to spontanious cumbustion as anything i have ever heard of.
    Also be aware that any locker sucks in snow, and gov lock carriers will not accept detriot lockers.
    just a little FYI from your local neighborhood Profile Police /forums/images/graemlins/thumb.gif
  4. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Gov Locs in 14FF's are pretty stout. There are a few stories about them breaking BUT most people with 14FF gov loks have had pretty good service with them. Thats from my personal contacts as well as those on this forum. My 14FF Gov'lok has stood up to a 454FI engine spinning tires on big rocks for a long time.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> My 2 cents - the first unit is operating normally, a govlock should act like an open diff when no power is being applied to it. I will also agree that 14b govlocks are generally pretty stout units. </font color>
  6. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I run 38's on a 14FF with a Gov-Loc behind an 88 TBI 454 and haven't killed it yet. I am not extremely abusive to it, but i make it work.
  7. Robbie6987
    Robbie6987 1/2 ton status
    Jul 16, 2002
    111
    killeen TX
    You should pull the cover off #2 if you can it could have a detroit.
