Need help with 205 rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Aug 3, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm rebuilding my GM 205 transfer case from and 87 pickup. One of the shifing forks is a little marred up on both "fork" end surfaces. Is that OK?
    Thanks,
    Eric M.
  2. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Anyone?? I wanna put it back together today if the fork is OK.
    Eric M.
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    if it was that way when u took it apart & it slides in the case alright i say go for it?
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    try to smooth it out with some emery cloth and polish it up a bit...also check the groove that the fork rides in in the shift collar for and irregularities...The forks are stationary and the collars spin, therefore you want it as smooth as possible or you will have abnormal wear promlem and possible noise..
    Chris
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    come to think of it...I think the forks have a raised "pad" towards the end of each side of the fork...it is the machined surfaces of this pad that is of importance...not the entire cast fork surface...
    Chris
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    "marred" metal is usually never good. It's a sign that something has gone wrong (foreign matter or lack of lubrication). It may be fine for a little while but will probably need replacing along with the mating shift collar. It's your choice. Put it together and gamble and hope nothing happens, or do it now and not worry about that problem.... I know I never win at gambling (I reason I won't go to Vegas), so I would replace it, but others have better luck than I do, so go with what makes you comfortable. You will probably pay $50 -$100 for the matching clutch ring and shift fork, so that may factor into your decision.
