need help with 60 swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudduck, Mar 22, 2002.
  1. mudduck
    mudduck 1/2 ton status
    Jun 30, 2001
    245
    wentzville mo
    can i still use my current drivehaft up front? what u joint should I use? got a d60 front out of a 85 dually it is going in a 79 shortbed that was converted to 3/4 ton already, what about steering,draglink, arm, the truck has a 6" lift? thanks need help
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The driveshaft and steering parts will bolt up. You may or may not need to change the brakelines
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    brake lines will match up, the driveshaft should also. You will need a 4" D60 steering block. the rest of the steering will work. I would sugest just going to the x-over. I am VERY sorry that I didn't.
  4. mudduck
    Jun 30, 2001
    245
    wentzville mo
    thanks for the info i just want to have everything ready so the swap can be done easily no parts scrounging thanks again everyone Scott
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The dana 60 steering arm will work, not yours. As for brakelines, if you have a 10 bolt up front, they will work, if its a dana 44 they wont.
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i had a D44 up front and mine worked fine...
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    D60 has a longer pinion you may have to shorten your front shaft if it is close on distance. I had to take 1" out of mine.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't the front hubs from a dually application make it the wrong width for our rigs?
