Need help with 78 Caddy Calipers w/park brake!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, Sep 24, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Having read the warnings from people like Shawn about not turning the park brake nut; I left my caddy calipers alone in the box & didn't touch them. The piston is out a little though as they were shipped. Problem is that with the new pads in them; they won't fit over my new rotors!! [​IMG]
    I need them to go back approx. 3/16 of an inch. They look like there's enough room for the piston to move back but how do I do it?? A special trick; special tool??
    Help!!!!
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Either the calipers weren't assembled correctly or someone turned the e-brake nut/arm pushing the piston out. If you bought them locally, take them back and exchange them. If bought thru TSM, call them and see what they suggest. Mine went over the rotors with about 1/8" clearance. Are you sure you have the correct rotors? Are both calipers the same? If so, I suspect they were assembled incorrectly.
    A good firm grip is my idea of gun control!
  3. Brian 89KBlazer
    779
    Ontario, Canada
    Yeah Sparky
    I bought them locally but I'm not sure there's even enough room for the rotor. The caliper I bought is for a 78 Caddy Eldorado & the rotors are 1.25 " thick Chevy 3/4 ton 8-lug ones. Were the pistons on yours advanced any when you got them or were they flush with the housing?
    Brian
    89KBlazer
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    You can turn them back, you have to get a large vice grips or something and manually turn the piston back, I had to do this on mine.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    what is the going price on these calipers?
    anyone have a great deal online?
