Need help with a calculation
Discussion in 'The Lounge' started by sled_dog, Feb 23, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Alright I located my rear under the buggy and I want to figure out what angle my lower links are at. I did some math and found that from the axle end of the link to the frame mount is a 1" rise. This takes place over 31.5". So can I take those numbers and figure out the angle of them? I asked my dad the master carpenter and he didn't freaking know /forums/images/graemlins/rotfl.gif said he always uses a "345" square so doesn't have to know it.
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i dont know if that will give you and angle. it will more give you a slope percentage.
    %slope vdx x 100
    _________
    HD
    vd = verdical difference
    HD is your distance.
    wait for an expert to reply though
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah you can do it, I forget how though, simple trig
    Your links rise and inch over 31.5"? I have no idea, but that doesn't sound right, maybe I'm just too ignorant of linked suspension
    Damn it..... trying to remeber triginometry
    Uh, from my ass math, I think 1.8*
    31.5" as the radius of a circle
    63" Diameter
    197.82" Circumference
    49.455" Through 90*
    1.82* for every inch of travel through the 90*
    Orrr uhhh yeahhhh
    I realize this method gets way more off as the inch in question gets bigger, but I figure it's around 2*
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    probably more like 18*. What doesn't sound right about it? The goal is the lower link as close to parrellel with the ground as I can get it.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    (sin) old hippies (cos) are high (tan) on acid
    sin (theta) = opposite/hypotenuse
    cos (theta) = adjacent/hypotenuse
    tan (theta) = opposite/adjacent
    Fell asleep in the sixth grade huh? /forums/images/graemlins/whistling.gif
  6. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Like I said dude, I have NOOOOO idea about linked suspensions, if the links are supposed to be flat as possible, I'll go with that
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    shut my mind off a few years ago. Been too long since Geometry.
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    1.82 DEG or 88.18 DEG off level
    Tell your dad to buy a Construction Master Pro /forums/images/graemlins/tongue.gif
  9. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Joe's got it right, that's just the hard way. Use the inverse tangent function on 1/31.5
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm no genius of this stuff, guys around here know a lot more than me. I just tried to get a little angle on the lower links, 10" distance between the upper and lowers, and half that at the other end. 45* angle on the upper links to control side to side.
  11. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I WIN I WIN I WIN
    This is like the time I went on a field trip to the dam in Pierre SD. I identified thier air compressors as old WW2 airplane engines, and I felt smart, but no prize, I said "Where's my dam prize?", get it? They didn't have a souvenier shop......
  12. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    You are looking for the angle relative to the ground correct? If so, take the inverse sine of (1/31.5). Which gives you an angle of 1.82 degrees.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    inverse tangent, inverse sine, which is it?
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ok 1/31.5(sin) and (tangent) both work out to 5.5*.
  15. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Tangent. It would be sine if the link was 31.5" long, not the distance parallel to the ground. The answer is almost the same because the angle is so small.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hmm looking at the pictures it does look more like 1.8*. My back is up against the fence of my dogs cage so I can't look any better.
  17. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Inverse tangent. It is 1.818302964
  18. justinf
    Sep 23, 2003
    684
    Tuscola, Illinois
    You're right, I looked at it and figured 31.5" was the length of the link. When you plug it in, it should give you 1.82 degrees, not 5.5 degrees. Like 84k5 said, with such a small rise over that distance, it doesn't affect it very much.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    inverse tangent, hmmm how do I do that?
  20. justinf
    Sep 23, 2003
    684
    Tuscola, Illinois
    Look at your calculator, most scientific ones have a shift key with additional functions listed above the keys. Usually, inverse tangent is listed above the tangent key. and is labelled tangent raised to the minus one power. (tan-1)
