Need help with alternator rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by grumpy, Jan 21, 2002.
  1. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    I pulled a 100 amp alternator of a diesel K5 and hoped to just throw it it but it doesn't charge (did a bench test) Can anyone give me some tips for rebuilding this thing? Is it worth it?
    Thanks,
    David
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    How did you bench test it?
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I did a rebuild once, never again. It lasted 1 month and crapped out. Not worth the 15 or dollars to buy it. Just my 2 cents.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  4. grumpy
    Jan 7, 2001
    353
    San Diego, CA
    Took it to a shop and they ran it to see if it put out current. Mine didn't
  5. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I rebuilt my alt. about a month after I bought my truck, didn't even get the rotor slip rings machined, just slapped it together. Still going strong 4 and a half years later. It'll prolly blow up tomorrow now that I've posted this[​IMG].
    James
    jimmy79@shaw.ca
  6. dyeager535
    26,982
    191
    I've rebuilt a couple, assuming the 100amp is the same, it's easy. Go buy a rebuild kit, there aren't many pieces at all, and its cheap. Hardest part is the bearings, they can be removed with a socket set and hammer IIRC : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
