Need help with axle/brakes ASAP please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Aug 12, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    OK, this is the first time I've done this, so bear with me. Prolly a stupid question, but I'm stuck and my Chilton's manual might as well be in Spanish for as much as its helping. I need to pull the rotor/hub assembly off. What else do I need to do to be able to pull it off??? Thanks. The pictures should do the rest of the speaking.
    <a target="_blank" href=http://albums.photopoint.com/j/View?u=1657641&amp;a=12907332&amp;p=52857075>http://albums.photopoint.com/j/View?u=1657641&amp;a=12907332&amp;p=52857075</a>
    '73 K5
    Chevy good...Ford bad
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    it looks like you are almost there...
    there was a big ring that you screwed off after you pulled the snap ring, and there is another one underneath that thing you see with a lot of holes in it.
    the ring with all the holes also has a little stud on the back side that is easy to break off so be careful. pull on it carefully, and it will come right off, and then you can screw the other ring off.
    at that point you are all done, and everything else should come right off. be carefull when you pull everything else off because your bearing will fall out (long story so don't ask [​IMG]).
    have fun!
    <font color=blue> Jeff - may the force be with you</font color=blue>
