need help with body bolt for body lift !
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by riz, Aug 10, 2001.
  1. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>As you all know, I'm replacing the rear floor section of my Blazer and now have reached a slight impass ........ I've got both sets of rear body bolts out completely and started in on the middle set ........ I soaked them real good with PBBlaster and at first it started to loosen, but then it just started to spin ! Is there one of those welded nuts on the inside that broke ??? If so, how in the world do I get the body bolt out ? I can't see how to get in at it at all ....... I have a poly bushing kit and 2" body lift to install while I'm at it so I need to get the old one out ! Any ideas ????
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Can you cut off the head with a die grinder? I don't know how you'd remove the rest of it when it's out, though.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    you have to drill a hole beside the bolt and weld the nut back in place
  4. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I used a 41/2" angle grinder grinded off the head and used a punch and hammer to drive the rest of the bolt out.
    [​IMG] [​IMG] [​IMG]
  5. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I have not got to this part yet. I just got my new urethane mounts and a 2" body lift kit for the old girl. I am going to wait till the floor is in; that should be in next weekend; hopefully. Later.
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I'm at the point right now where I can put my new floor in and have a big question ............. How in the world do I get the floor with the tailpan attached in place ? I know a couple of you said to spread the fenders out a bit but others said not to ......... I'm racking my brain and it doesn't seem like it's going to go in without lifting the body way up or spreading the fenders out some ............ please help out any way you can !! I'm making great progress and don't want to be halted for too long ....Thanks !
    L8r,
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    back on top ...anybody ????
    L8r,
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Damn Riz, I wish I could help. But without seeing it up close, I can only suggest takin a fresh look at it after some sleep. I know I've been caught up in something, wanting to get it done and the old brain stops working after awhile. lol......
    <a target="_blank" href=http://fwp4x4.rockcrawler.com>fwp4x4.rockcrawler.com</a>
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I heard that, It's just that I've gotten so many ideas from you all in the recent weeks and now that the time to really do it is at hand, I want to be refreshed on how the best way to do it would be ......... I don't want to screw up !!!!!!!!
    L8r,
  10. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I can't say I can be of much help... but I do know that over at Ken's 4x4 they do a ton of body lifts and are great guys. I'm sure they would be more then happy to lend you an idea or two... try giving them a call at 1.800.421.1556
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  11. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I had the same problem and ended up cutting a square hole in the floor board with a Dremel to gain access to the bolt. You don't have to cut the square out. Just cut 3 sides and fold the sheet metal back. Once you are done fold back the piece of sheet metal and have someone weld the piece back in. Or you could make a cover plate and bolt it over the hole.
  12. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Make sure to install the wheel wells last, this will at least give you some room to work with. I would definitely spread the rear quarters out, this is the easiest way to do it. You will not have to move them that much, so you will not damage the quartes at all.
  13. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Thanks a lot guys ! I appreciate the ideas !
    L8r,
  14. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Hey Peter, When are we going to see that 2nd installment of the floor install !!
    L8r,
