Need help with brakes PLEASE!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Kodiak, Feb 27, 2002.
  1. Kodiak
    Kodiak 1/2 ton status
    Mar 17, 2000
    178
    Kodiak Island, Alaska (the emerald isle)
    I've got a problem that seems to be getting worse. The majority of time, the brake pedal is hard like normal. But lately, the pedal has become soft at times. It is very inconsistent, but seems to happen more when the motor is cold. Whenever it is soft, I pump it once and it is back to a hard pedal. It has nothing to do with how often the brakes are used or how long its been since the last time I pushed the pedal. This morning, it was so soft the pedal did not want to return to the up position. I stuck my foot under it and pulled it back up, then push it back in and it was back to being a hard pedal again.
    I have found no leaks or anything obvious. What can be giving such an inconsistent problem?
  2. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    that happens to my truck and my friends chevelle but we have learned to deal with it by doing a quick, short pump before u fully apply the brake.
    Evan
    1970 Blazer, <font color=orange>ORANGE</font color=orange>, 3-speed manual, 33's <a target="_blank" href=http://community.webshots.com/user/aksidentproan>Love Shack Pictures</a>
  3. Kodiak
    Mar 17, 2000
    178
    I don't mind pumping the brakes. What I don't like is I didn't have to before, so something is not working or wearing out. I would rather replace it than depended on pumping the brakes for a long term solution.
  4. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    Have you tried bleeding the brakes? It fixed all my brake problems..
  5. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    It could be a Master Cylinder problem. I had that happening on my truck for a while, I changed out the Master Cylinder and did not have that problem again. As far as the pedal not returning, that sounds like a your return spring on the brake pedal fell off. Good Luck.
    See Ya,
    Keith
    "Your just mad cause the voices only talk to me."
  6. Kodiak
    Mar 17, 2000
    178
    On the pedal not returning, it only happened the one time and worked fine after that. I have thought of replacing the master cylinder and the power booster, I just don't know wich one would be causing this problem or how to check the function of each seperately.
  7. californiak5
    Oct 25, 2000
    820
    I think if the power booster was going bad that you would not have the problem with pumping the brakes. You would always have them, it would just feel like manual brakes. Meaning they would be real hard and would take more force from you to stop your truck. The pumping of the brakes makes me think it is the master cylinder not holding presure, which in turn makes you have to pump the brakes a few times to bring the presure back up. I could be wrong, but it sounds like what happened to me and the master cylinder change fixed my problem. Plus the master cylinders are pretty cheap for our trucks at Napa and Pep Girls and such. If you change it out just make sure that you bench bleed the master cylinder first before hooking it up to the rest of the system and bleeding all of it.
    See Ya,
    Keith
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    just a thought. check the rubber grommet of the vaccum tube that goes into the booster. mine had a little leak and sometimes it would leak others it wouldnt and that gave me diffrent breakin probs from time to time.
    nathan+
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    You have a fluid leak somewhere. This is not safe. Is it losing fluid? You need to find the leak(s) and fix it (them).
