need help with D60 hubs
Discussion in 'The Garage' started by mudduck, Apr 30, 2002.
  1. mudduck
    mudduck 1/2 ton status
    Jun 30, 2001
    245
    wentzville mo
    found good set of single wheel hubs traded my dually hubs for them but i have to swap them myself what tools should i take and does anyone know which hub socket or wheel bearing wrench to use? have part number? any help thanks Scott
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    that's not to hard you will need a hub socket but check what type of hub nuts you have 60's came with both 4 or 6 slot nuts/forums/images/icons/smile.gif you will also need a set of snap ring pliers.theres not much else to it. but if you plan on using yer old rotors you will have to remove them from the hubs, that is simple but can be a bitch if they are old and rusted. but thats nothing some PB blaster and an impacked wrench won't fix. but if you plan on using the dually rotors the stud hole will have to be reemed out to except the new SRW hub studs.
  3. mudduck
    Jun 30, 2001
    245
    wentzville mo
    thanks thats what i needed to know thanks
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sent you a PM.
    BTW, it helps the parts guys at the stores if you take one of the spindle nuts with you to find the correct socket. /forums/images/icons/wink.gif
  5. mudduck
    Jun 30, 2001
    245
    wentzville mo
    thanks wes, cant find a socket here anywhere that will work to take mine apart, took lockout off , need a 4 prong socket and cant find one that will work, still searching thanks again Scott
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Have any Murray's Discount Autoparts stores near you.
    They always have them by me.
    Ken H.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Checker and Napa have them I know. Probably Autozone too.
  8. mudduck
    Jun 30, 2001
    245
    wentzville mo
    thanks alot guys finally found one at Napa had to drive a ways to get it but no one had the one i needed Auto zone had a loaner but someone had it out they only had one got my hubs off and now i will be single wheel by friday thanks again.
  9. beater74
    May 29, 2001
    1,749
    atlanta
    BTW are you getting new rotors in yer DRW to SRW hub swap or are you reusing yer DRW rotors.
  10. mudduck
    Jun 30, 2001
    245
    wentzville mo
    i will use the rotors that came with the single wheel setup, is there a difference in the rotors?
  11. beater74
    May 29, 2001
    1,749
    atlanta
    theres not much of a diff. only on the DRW the rotors are bolted to the hub and on the SRW hub they use press in studs to hold it together. i'm using my DWR rotors and have to have the holes reemed out to except press in type studs.
