need help with driveshaft for bigger lift...
Discussion in '1936-Present Suburban' started by Kartoon, Nov 29, 2005.
  1. Kartoon
    Kartoon 1/2 ton status
    Jun 14, 2005
    171
    Massachusetts
    i have a 4" lift on my 90 suburban right now and in the future i would like to go up to a 6-8" lift. i think ive read on here that the most you can get away with the stock driveshafts is 5". are there companies that sell driveshafts already extended, or do i need to send mine out? what are good companies to use? and the most important question- how much should both drive shaft be extended. thanks for any help.
  2. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    i had 6" in my 1ton with fixed yoke rear. and no problems with it. had flip kit in the rear also. some need them some dont after 4" of lift or more. longbeds tend to get away with 6" . front will need to be done tho.
  3. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    is it all right to run slipyokes? what good shops can i get one made at?
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    HAD(High angle driveline) Jess is a good guy to deal with.
  5. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    this is my front driveshaft with my 4" lift.
  6. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    someone help me?
  7. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    That pic isn't too good. Are there any splines showing? I had my front extended 2" with a 5" lift. I really could have gotten away with 1", but I wanted the option to go bigger later.
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    watch that drive shaft being TOO long, if it runs out of compressiopn it can spell bad things for your t case.
  9. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    You really need to measure what lengths you need at full droop and compression, and check your stock shaft to see if it will work. I wheeled the piss out of mine quite a few times and she never bound up on me. Like I said, 1" was good for me but I planned to lift it another 1-2" so I went with a 2", but I also had more travel in my slip yoke to accomodate it.
  10. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    What tranny/transfer case do you have. I have the driveshafts for 8" lift. I had the sm465/np241
  11. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    its in all stock 3/4 ton, 350 suburban. if thats the same for what you got, PM me.
  12. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    What kind of transmission/transfer case do you have. I had the sm465/np241.If you have the TH400/208 it won't work because the front driveshaft will be too short & the rear too long
  13. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    well when i looked online, it seems that the sm465 is a manual transmission, and since mine is an auto id say they wont fit. thanks anyways.
