Need HELP with EATON REAR END
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by proyouring71nova, Mar 19, 2003.
  1. proyouring71nova
    proyouring71nova Registered Member
    Jul 17, 2002
    39
    CA San Rafael
    So i have my Eaton (69 chevy 3/4 ton rear end) rear end all apart and have a locker ready to be put in it but I went to my friends auto parts store and he could only come up with one kit for a Ring & Pinion instal kit and the price was $590.90 that is for 2 carrier bearings, 1 pinion bearing and, 10 shims, and 1 crush sleeve. So what I was wondering dos this sound right, I know that this rear end is old but come on $600.00 just for parts, Dos any one know about any places that sell these kits cheaper, Any help would be appreciate, thanks max
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thats how it is man, those eaton axles were last made in 72, they are dinosaurs, id just get a 14 bolt or dana 60,
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I bought a complete Timken kit for Pinion shaft only and it was, around $210.00. These are a special Double bearing/outer race/combo.
    matched Set from the Factory. /forums/images/graemlins/blush.gif
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Do you have the load bolt on the side of the housing for the pinion bearing? That will change the price of the kits. Also tell me what your looking for exactly. /forums/images/graemlins/thumb.gif
  5. proyouring71nova
    Jul 17, 2002
    39
    CA San Rafael
    It has no load bolt, I would like the pinion bearing, pinion preload shims or crush collar, a pinion seal, Shims, pluse carrier bearings? Everything in a install kit thanks for the help max
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The Pinion kit come's with, 2 bearing's, and one Race.
    The Race is for the Pinion Bearing's, [a matched set from the factory]. Brand name "Timken"
    All You need is the Carrier bearing's, available at Good Bearing House's, and the Rear Pinion Bearing, [ a roller ] type with a cage. It support's the "Snout" of the Pinion Shaft."Timken Bearing's" and a CR Pinion Seal
    and a few Shim's.
    I've got all the part Number's if You want them.
  7. proyouring71nova
    Jul 17, 2002
    39
    CA San Rafael
    ya, can you send the #'s my way? thanks for the help, max
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    As soon as I can remember to bring em here, I"ll do that for ya. /forums/images/graemlins/1zhelp.gif
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    O.K. I remembered the number's, here You go.....
    1.Pinion Set, TIMKEN 55197 90030 $205.53
    2.Carrier Bearing's, TIMKEN KD11786Y $50.00
    3.Rear Pinion Bearing, SKF M5205-UV $27.00
    4.Pinion Seal, CR 25970 $8.00
    1960-1972 Eaton, Common Number, H072
    /forums/images/graemlins/eek.gif /forums/images/graemlins/shocked.gif
