Need help with engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dutterback, May 30, 2000.
  1. dutterback
    dutterback Registered Member
    Mar 12, 2000
    22
    Missouri
    I just went out in my blazer and started it. As soon as I put it in gear it died. Now all of the sudden it is doing this every time it is in gear and idling. In park it seems to do fine, it just dies every time I put it in gear. I took off the air cleaner and it looks like the injectors are putting out good fuel. Anyone got any ideas as to what it might be? I hear the fuel pump in the tank come on every time prior to starting. It is an 87' with a 350 tbi.
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    When was the last time you replaced your fuel filter? Tune up? (to include timing?)
    Plus that truck is getting pretty computer controlled by that time. Is it throwing codes?
    Corey
    88K4
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  3. dutterback
    Mar 12, 2000
    22
    Missouri
    I got a fire call a couple hours after I posted this. I started it and ran down the highway at about 80 mph for about ten miles. Now the engine seems to be doing fine. I dont have a clew what was wrong, but I hope it doesn,t happen again. Thanx.
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i think you need a tune up.
    but remember engines sometimes need a good push for about 10-15 minutes (i.e floooooooooor it!!!!). to remove carbon deposits and junk.
    look at it this way, a good sprint for you every now and then is good.
    Knife.
