<<<<<Need Help with Fuel Pumps>>>>>
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jan 25, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Ok, Im pissed [​IMG] last week fuel pump gave out on the highway had to get a tow home. Yesterday, I had enough time to replace it with one with a lifetime warranty from AutoZone [​IMG]. I get school ok this morning, but on my way home it stalls, get it started again, go down the road for approx. 2 minutes and it stalls again. Did that 3 times till I got to a side street and had to get a another tow. I'm pretty sure that it's just a poorly made pump that's giving me hell, but I will test it tommorrow. My question is what do yall think is the best mechanical fuel pump out there(Hollley, GM etc) Thanks.
    Murphy's Law :
    "When you don't know what your doing, do it neatly."
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I checked out your profile and noticed that you have a 305. In case you didn't know, 305s are well known for a wearing out the cam lobe that runs the mechanical pump.
    I had a bout of fuel problems 6 or 7 years ago, and after going through 4(YES...... 4!!!!!!) pumps in about 6 months, a buddy suggested I scrap the mechanical pump and go to an electric pump. I installed a Carter 2-stage pump back by the gas tank and haven't had one problem since........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks for yet another reason why 305's suck [​IMG]
    How difficult was it to install the electric pump.
    Murphy's Law :
  4. Can Can
    15,552
    136
    The pump itself is a piece of cake to install- the kit comes with a bracket that can be screwed/bolted to the underside of the floor or a framerail, for example. The pump is attached to the bracket and then the fuel line has to be cut and attached to either side of the pump. Carter recommends installing an in-line fuel filter between the tank and the pump, too. I had a buddy wire the pump because me and electrical things don't get along[​IMG]!!!!!!! You can either keep the mechanical pump in place or eliminate it- I removed mine and bought a little chrome plate to cover the hole on the block. I'm not sure which set-up is better........
    I found that my overall performance increased with the electrical pump, and the little hum coming from the back of the truck is kinda' cool too!!!!
    FYI, the closer the pump is mounted to the gas tank, the better.
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Find an AC Delco mechanical pump and try that first. I have had cheap new pumps fail pretty fast.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Stay away from thoes Auto Part chain stores!! All of their stuff as far as I'm concered is ALL CRAP[​IMG]!!!!!!!! All of IT!
    Hell I won't even by oil at thease places, just the thought of walking in makes me ill!!!
    Summit sells an electric fule pump kit that even comes with a fuel regulator all for 79.95! Check it out part # is SUM-G3132.
    Also Holly makes a pump for 67.50 # HLY-12-801..
    Good Luck hope this helps
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  7. Can Can
    15,552
    136
    Just so you guys know, two of the pumps I replaced were ACDelco, and two were less expensive parts-store pumps. In the end, the only solution was the electric pump.
