need help with injectors not firing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fright98, Jul 15, 2006.
  1. fright98
    fright98 Registered Member
    Nov 21, 2005
    32
    south of Boston
    Seems my injectors are not firing. And the truck won’t start.
    I took the fuel pump out of the tank and mounted a holly in line on the frame. The new pump did not resolve the issue but at least it’s out of the tank. I also replaced the ignition control module. The fuel is making it up to the carb or whatever it is on a tbi.
    I have been doing searches all morning but still have not resolved the issue.
    Somebody mentioned that if the ecm does not see a spark it will not fire the injectors.
    With a code reader on. service engine flashes once then twice
    Just got my new drive shafts in from HA and wanna go for a rip.
    What might be causing my injectors not to fire?
    [FONT=&quot]Should I go grab a new coil?
    [/FONT]
  2. fright98
    Nov 21, 2005
    32
    south of Boston
    ecm from the parts blazer did not help.
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    what kind of FI is it?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That code is just a 'hand shake'. Ignore it.
    Check that you are getting power to the injectors in start as well as run. Could be a fuse or wiring problem if you've power at the injector. If I remember correctly there should be constant power to the injector which is then triggered by the ecu.
  5. fright98
    Nov 21, 2005
    32
    south of Boston
    90 with tbi
    What would be the best way to check for power to the injectors. I do not have any diag tools.
    [FONT=&quot]Battery light stays on now when the key is forward and the service engine soon light too
    [/FONT]
  6. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    maybe bad injector
  8. fright98
    Nov 21, 2005
    32
    south of Boston
    Done for the day. This has got to be something stupid.
    Battery and service engine soon light stay on . It will not fire when I put some gas in the carb and turn it over.
    New icm
    New cap and router
    Tested with different ecm
    Alternator new about a month ago when engine was swapped
    New coil
    Tested with different battery
    No codes
    Tested with injectors and housing (not shore what its called) from parts truck
    Seems to me at this point that my injectors are probably ok. Assuming that no spark will tell the ecm not to open the injectors
    [FONT=&quot]Battery and engine light. On. Any thoughts. Thanks[/FONT]
  9. eclmech
    eclmech Registered Member
    Apr 9, 2006
    24
    Ontario, Canada
    Pick-up coil maybe?
  10. 4xcrazy
    Oct 31, 2003
    9,471
    5
    i was thinkin the same thing, had that happen to mine awhile back, no spark, did the same thing with swapping out parts, then just pulled the dist and found the burnt out coil...
    been fine with THAT anyways, ever since
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    really don't know if this will help, theres 2 articles on it here.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I vote pick up coil also. Code 12 with no fuel out of the injectors is usually either a dist module or pickup coil
  13. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I agree, I had the same problem with mine a few years ago. Changed out the pickup coil and it started right up. :D
    Rick
  14. fright98
    Nov 21, 2005
    32
    south of Boston
    New distributor and it up and running.
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Good job!:D
