need help with my rancho 4in lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DALE, Jan 12, 2001.
  1. DALE
    DALE Registered Member
    Aug 27, 2000
    44
    hey everybody today is a great day i just back from picking up my truck from getting my 4in rancho lift put in,but the problem is the guy at the shop said he could not get the inner shocks to fit (quad shocks up front) the part # 9001.are these the correct ones? also my front stabilizer did not fit. the part #5404.is this the the correct one.also the shop never put in the transfer case lowering kit. do i really need it. please help. i just got off the phone with desart rat where i got all my susp parts and i checked with the guy there and he said that i had all the right parts.he could't understand why they didn't fit.i have the rancho 9000's.***** now the license plate on my 90 blazer fits perfect RIDNHI
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    A lot of people with the front quad shocks say it rides a lot better with just single shocks up front anyways. I can't imagine why they wouldn't fit though.
    If your truck does not vibrate when you drive it you don't need to lower the T-case. That is just a fix for poor driveline angles.
    No idea on the stabilizer, mine must be 10 years old.
    Rene
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I think you have the correct part #'s. When I originally did my lift I put the quad shocks on. Don't waste your time putting them on, you don't need them. That probably doesn't make you feel any better now that you have them, but the ride will be 100% better without them. If you really want to put them on, it will take a little time, patience, and a few new words, and a BFH will help.
  4. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    on the transfercase you will have to lower it the thing wont vibrate so much it will howl its really annoying ,remember to adjust the linkage also running quad 9000s 2 have to go upside down and the listed ones dont fit they have to be measured to fit or theylle be to short .
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  5. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Dale,
    By any chance are you located in AZ? If you are, what part of the valley? I may be able to give you some help. Also, go back into your profile and fill it out.
    GOT ROCKS?
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Dale
    THe stock shocks on the front a real skinny for the dual shocks....as other have said it is a stiff ride with dual shocks on the front.....but if you want them invert them....
    I don't have my book for the Rancho shock for the Stabilizer....
    I haven't lowered my t-case in 4 years......I've been thinking about ting it to see if there is any difference.....
    If your in the East Valley, let me know if you need a hand.......
    C'moe
    <font color=black>the blazer is "Back in Black"
  7. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I had Quad shocks.....I run singles.....rides better....
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate
  8. DALE
    Aug 27, 2000
    44
    hey guys thanks for the help.if i put in the trans case lowering kit i think the front drive shaft will hit the exaust, what should i do???????????
  9. DALE
    Aug 27, 2000
    44
    adjust what linkage?????????????????????????????
  10. DALE
    Aug 27, 2000
    44
    THANKS FOR THE OFFER, BUT I LIVE IN DANBURY, CT
  11. coopertwpk
    Mar 18, 2000
    478
    the front drive shaft will hit no matter what you need to have it lowered for about 50$ they just cut and curve it down ,the transfer case needs to be lowered just put the spacers between the frame and cross member ,the transfer case linkage then needs to be recentered otherwise it will jump out of 4high
  12. DALE
    Aug 27, 2000
    44
    don't you think my lowering kit will work better, the one i got from rancho then using the spacers???????????
  13. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    How do you go about recentering the linkage??? I'm going to be lowering mine on tuesday and thats the first I've heard about it?? Thanks!
    Dawson
    88 K5
  14. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    What did you Rancho loweirng kit come with?
    Dawson
    88 K5
  15. DALE
    Aug 27, 2000
    44
    my rancho trans case lowering kit came with 4 spacers and nuts and bolts.do i put 2 spacers or 1 on each side in between the fram and crossmember. help!!!!!!!!!!!!!
  16. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    There should be 4 bolts holding up your T case crossmember right now along with spacers and nuts replace the old bolts with the new ones and put the spacers in-between the crossmember and the frame. Did you adjust your linkage?
    Dawson
    88 K5
  17. DALE
    Aug 27, 2000
    44
    hey dawson44 how do i adjust the linkage please walk me through it
  18. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    yes, how do you adjust the linkage. i had mine lifted and droped the tranfercase, but didn't know about adjusting the linkage and mine does jump out of 4hi
    '85 Jimmy in Jax, Fl
  19. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I wish I knew how do adjust it, but I don't, I am going to be lowering my T case on Tuesday and I need to figure it out. I am sitting here with my Haynes manual, which covers how to do it, but I'm still clueless, maybe someone else can help??? I also have heard you need to adjust the linkage with the tranny if you have an auto, anyone have any input???
    Dawson
    88 K5
  20. coopertwpk
    Mar 18, 2000
    478
    Ok on adjusting the np 208 I shifted it into 4hi then 4lo to see the distance off ,had my wife sit inside to watch the shifter to see when it was centered then adjusted it more with it running you can feel the center of the shift points especially 4lo once it was centered it aligned inside right and wont jump out of gear anymore.
