Need Help With My Welder
Discussion in 'The Tool Shed' started by Drey, Mar 25, 2007.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Its a Hobart Handler 180. I havent welded any thing with it yet but my dad has and he said it works great. But we have a problem. As soon as you turn on the gas it is purging it out of the gun constantly.
    It should wait until you pull the trigger, then go but it just goes all the time, whether your feeding wire or not.
    I checked my manual. There was nothin in the troubleshooting section about it.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Might wanna check out the wiring and see if the solenoid is stuck on. Shouldn't be too hard to figure out really. The gas system should be fairly simple.
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    if its not what is mentioned above could be a leak past the diaphragm in the regulator possibly......hmmm, although it would probably leak even if it was not on, but I would still check it.
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    sure it's not supposed to do that to cool the tip and does it on first power as a default?
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Dad tore it apart the other day and there was a chunk of rubber stuck in the silinoid not allowing it to close. We couldnt figure out where the hell it came from either.
    Anyway it works perfect now
