Need help with new truck
Discussion in 'The Garage' started by 53chevy, Jan 20, 2005.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    HI, i just got a 84 GMC 1 TOn with 12 inch lift and 39.5 boggers. It has 5.13 gears in the 14 bolt in the rear. How do i tell what gear ring size and if it is FF or Fs axle. Reason i need to know is i need new rear brakes and want to do a rear disk conv. Thanks for your help
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Well, if your cover has the same shape as this:
    then it's a 14 bolt full float. The ring gear size is 10.5". If the cover is more of an oval shape, it's a semi float axle and the ring gear diameter is 9.5". Another way to tell is by looking at the hubs. If there are 8 bolts on the end of the hub, it's a 10.5" full floater.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A 14 bolt FF has 8 bolts that go through the axle flange into the hub. This is not my pic, I grabbed it from the web.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Sounds sick man!! Wheres pics. It most likely has a FF.
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    If it is infact a 1 ton from the factory it will be a 14BFF unless it was swapped out for some reason. Just look for the large hubs sticking out of the center bore of the rim. Like pictured above.
