Need Help with Power Steering Leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Sep 20, 2001.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I have a serious power Steering leak that developed after my last wheelin trip. I figured it was one of the hoses but upon further inspection I believe it is leaking out the bottom of the box where the splined shaft for the pitman arm comes out. Is there some sort of a seal that can be replaced? Where do you get this seal, do I have to tear down the whole box or can I drop the pitman arm and replace it from the bottom? Any Ideas or thoughts would be helpful thanks.. :)
    BlazerBoy
    <a target="_blank" href=http://www.geocities.com/generalblueballs/>http://www.geocities.com/generalblueballs/</a>
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If your gear box is old then I would recomend getting a new one. Because if you change that seal, Im sure shortly down the road the seal where the steering shaft comes in will start leaking. I believe that you have to pull it apart.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. BlazerBoy
    639
    Chicago IL.
    I am not sure how old or used and abused this box is. It has only been in the truck for a couple months I pulled it from a Suburban from the bone yard when I did my cross over.
    BlazerBoy
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    I rebuilt my steering box with almost no problems. (when I say rebuilt, i replaced all the seals) However, fair warning... If you pull it apart completly you will have a hard time getting the worm gear bearings back in. It looks like a fairly simple thing to take apart and put back together, but unless you are very mechanicly minded, you will not get it back together. Also, I know there is a special tool you can use to get the bearings back in, but i dont know how much easier it makes it. I had to shove the bearings back in with a screw drive and then carefully stack them in this two piece loop thing. It took more than two hands so have a friend handy. Its by no means impossible, but like i said, its not easy either. My seals came with instructions, but my intuition turned out to be more useful than the instructions. Good luck
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  5. BlazerBoy
    639
    Chicago IL.
    where did you find the seals?
    BlazerBoy
  6. Grim-Reaper
    7,385
    Atlanta
    AutoZone. I just replied to another user on how to replace these seals as well as the input seal.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
