Need help with Rounded Engine Oil Drain Plug
Discussion in 'The Garage' started by tomy, Feb 20, 2005.
  1. tomy
    tomy Registered Member
    Jul 19, 2003
    34
    Orland Park, IL
    I'm a new owner of an 89 Silverado. I was attempting to change the oil and wasn't able to remove the drain plug. I tried to use a 13/16 socket on it and I justed rounded the corners. Any advice on what to try next?
    Thanks:confused:
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Righty Tighty, Lefty Loosee
    Gator Grip Socket
    Grind two flat edges, and a pair of locking pliers
  3. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    Thanks but I tried the locking pliers and they just kept digging up the head. The head of the bolt is a low profile and it's really difficult to get a bite on the edges. Any other suggestions?
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Counter-clockwise. Lock 'em down real tight. Otherwise I suppose the 'ol drill and easyout. Might file or grind a notch and chisel and hammer or trash a screwdriver tapping against the notch.
  5. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
  6. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    Thanks for the suggestion but the bolt out sizes are too small. I need one to fit a 13/16 bolt and the largest the Bolt out goes is 11/16. Any more suggestion?
  7. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    do you have air chissle?
  8. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    NO air chisle I just have basic hand tools. I didn't think changing the oil was going to turn into such a project!:(
  9. sweetk30
    Nov 1, 2004
    25,537
    536
    do you have a sharp hand chissle and good size hammer? i have a neat trick for you if you do. it works all the time for me at work on customers cars.
  10. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    I do have a hand chisle and a hammer. What's the trick?
  11. sweetk30
    Nov 1, 2004
    25,537
    536
    o.k. try to under stand this. take chissle and cut in to plug in to the center of plug at the gasket lip on plug, when in about 1/16-1/8" take and angle chissle to hit plug and move it to the removale direction. and the shock of the hammer and the bite of the chissle should work.
    try to get the motor hot first to expand the plug and pan a little. or heat the plug with small torch if you have one.
    DONT CUT THE PAN this is a given tho. just a reminder to you .
    this works best with air chissle and stright bit thats why i asked you.
    if you dont feel good with this take to a shop and see if thay will do it for you.
    hope this helps. if not clear on this ask me to clearify it .
  12. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    Technican b says:
    the chisel thing is what i usually do, if that doesn't work get a file and clean the bolt up a bit, spray some wd-40 or pb blaster on it and let it sit, get a 6 point socket and tap it onto the bolt, if it is rounded off file it down to the next metric or standard size and then tack a socket and tap it on with a hammer, (get a shallow socket) when its on get a ratchet and give it a quick pull, if that doesn't work or nothing else will chances are if you take it to a shop they will want to replace the whole pan for liability reasons, if thats the case- go buy a pan for cheap if you can't find one i may have one, and put it on yourself and save some money.
    Let us know what's up
  13. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    Thanks everyone. I'm headed out to the garage to try the chisle trick. I'll let you know how it works. Now if only my girlfriend would quit telling me how stupid I was to buy a 16 year old truck:D
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Take it too one of those oil change places and let them deal with it, LOL.
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    What plug are you trying to remove? The engine oil drain plug is 9/16's, not 13/16's. :eek:
  16. tomy
    Jul 19, 2003
    34
    Orland Park, IL
    It's the engine Oil drain plug and it's definitely 13/16. Maybe the previous owner modified it. It's the only plug on the engine oil pan.
  17. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    get a new pair of vice grips on it and make sure your going in the right direction, working over head upside down can confuse you.
    if not drill a hole in the nut and tap an ezze out in there and use it then put a new 9/16 one in there
  18. diesel4me
    Jul 24, 2003
    17,542
    936
    Massachussetts
    Try this.....
    I've gotten some pretty badly mutilated drain plugs out with a pipe wrench!--they bite in and grab even a rounded one pretty good..
    The chisel idea might work,but one slip and it goes right thru the oil pan!(especially with an air chisel)--since most oilpans are rusty and weak after 16 years,you might want to try all other options first,like welding another nut onto the drain plug if you have access to a welder...if not,maybe one of those special sockets that grab rounded bolts would work--I got a set for christmas from my brother,on my rusted junks it saved me quite a few headaches already!(Sears sells them in the "Craftsman" tool line)..:crazy:
  19. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I prefer to weld another nut on :xmas:
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've got both a 6" pipe wrench and a set of twist sockets in my toolbox, dont know how i ever lived without either of them...
