Need help with this VDO Tach, Please!
Discussion in 'The Garage' started by chriskh, Oct 28, 2005.
  1. chriskh
    chriskh Registered Member
    Jul 10, 2005
    31
    Castle Rock, CO
    I just purchased this VDO Tach and I don't know where the wires go. I have posted pics below for help. Can someone tell me how to wire it in my '76 K5 Blazer??? There are a total of 5 wires all together (green, red, white, blue, and black). The blue and black wires are spliced together for some reason or another... Anyone know why?? Please tell me where these wires go. I need help! I have no experience with tachs so this is a first for me. I appreciate all the help I can get. Thanks!
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm sure I've got some paperwork on that somewhere. I'll have a look at work tomorrow.
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Usually they are very standard:
    Green: Neg side of coil or tach plug on hei
    White: Dash lights
    Red: Hot
    Black: Ground
    Blue: Just a guess here but since it is spliced to the black purhaps it is a ground for the light?
  4. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I used a vdo one time and the dial to set the size engine 4 6 8 did not have stops built in to indicate which on it was working in. Well it caused me to turn a engine nearly 14k. I regularly turn it 9-10k during races so it is always loud. but people in the pit said they have never heard a car turned up so high. Its a long story but i hate those tachs. The motor threw the #1 rod out and it destroyed the entire motor. Just dont use it and trust it. I had a helmet on and could not tell but daily driver you will know if it is right.
  5. chriskh
    Jul 10, 2005
    31
    Castle Rock, CO
    Thanks guys. The guy I bought it from had it in his 350 V8 (same motor I've got) hot rod so I know it will work fine and it is set to "8" inside. Now I just have to find the tach plug on the hei. Any one know what this looks like or where it is?
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Early HEI (pre TBI) has it writen on the dizzy where your power wire goes in.
  7. chriskh
    Jul 10, 2005
    31
    Castle Rock, CO
    Well, I found it.... I wish I had an oem plug to stuick in there though. I guess I'm going to have to get creative. I appreciate all the help you guys have given me! Thanks butt loads!:bow: :k5:
  8. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    mine is hooked up with just a run of the mill blade style connector... might have required some creative bending of the connector... and i KNOW it required a lot of swearing as there was a ton of stuff in the way that prevented me from seeing the actual connector i was plugging in 90% of the time
