Need help with tire problem - *Update*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newyorkin, Sep 29, 2001.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Ok, a week or so ago I posted about a possible bent axle. Well, I haven't had to drive more than 3 miles a day, so I haven't worried about it until tonight, prepping for a drive to NYC tomorrow morning.
    I jacked it up and spun the tires, and noticed a big lump in my pass side tire, and the inner tread seeming to rise up.
    Here're photos: k5.8m.com
    Welcome to America. <P ID="edit"><FONT class="small">Edited by newyorkin on 09/29/01 12:34 PM.</FONT></P>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Re: Need help with tire problem
    Either a snapped or about to snap belt ya got there[​IMG] - probably hit a rock or pothole just right and bruised it. While it'd theoretically hold up to driving 80 or so miles, I'd be a little hesitant to take it over 20 mph.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Sounds like almost when you have a hose with a weak spot the pressure builds in that area and presses out... like a funky bubble forming and then when it gets weak enough and enough pressure builds it break... I don't know how to explain it... like when the tire came out it had a place that was tweeked and not the right thickness compared to the rest of the trie... or it could be something seperated or snapped in there and is now making that bump and wearing it thin in that spot really quickly.... I wouldn't knowing drive on that but that is me... never know when it could let go. Would suck if you were on the highway and going 65mph...
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  4. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Yorkin'...I wasted WAY too many years as a tire-buster. What you got there is the classic case of a busted/slipped belt. It could blow right now where it sits, or hold out for a week. Don't let your kids walk anywhere near the truck!!! I had one that got me back home and then blew while it was parked!! I wouldn't drive an inch on that tire...and I'm a CHEAP bastidge!!! If you go NEAR that tire...wear safety glasses and let the air out and get away fom it!! This comes from a guy that used to routinely break down split-rim truck tires including stuff left over from WW2! Don't risk it.
    9/11/01..Never forget...Never forgive
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Im a tire changer too and I totally agree with the advice just given by EDdaTree
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Shoot, that's what I was hopin' not to hear... But that's why I posted! Awesome response!!
    I drove on it so long not knowing what it was I figured I could keep going a little more, but I'd rather remain uninjured...
    EDda, you've got me thinking I might just go out and deflate it right now...
    Tire shop instead of work tomorrow I guess! Cripes, that means I'll have to use the un-inspected Heep to get the new tire...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    Welcome to America.
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Also lookes like you have been runnning your tire pressure lower that you should... the tires are not wearing even....Time for new tires
    C'moe
    Kill Roy was here!
  8. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    If you're running rubber valves...just rip it outta the rim with vice-grips and run like hell. If ya got a valve-core tool...loosen and go to bed. If ya got steel valves, loosen outside nut and bail. Can't stress enough how quick ya can get screwewd up by a tire blowing!
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Yeah I read about a guy getting killed once filling up a tire for someone that just stopped by his shop. I gained a new respect for 35PSI and tires!! I have a core tool, I'm just going to loosen it and hit the sack.. I was s'posed to get up in 4 hours...
    Thanks for the responses!!
    Ratch
    Welcome to America.
  10. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    35 PSI will still blow your head off!! I can finally sleep now that I know you'll be okay. Give us an all-clear when ya loosen the core and get back okay, okay?
  11. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
  12. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    LOL, sorry for no update last night!! I finally crashed at 4 after watching another round of WTC tear jerker's then airing the tire down.
    Apparently that tire was in pretty bad shape all around. When I pulled it off the rim at my buddy's junkyard, the inner bead shredded...
    And I totally messed up setting up the spare the first time around; it's on a Heep 6-lug wheel, and the centerbore doesn't fit the rear hub. It's also an 8 inch rim with a 12.5 tire, so getting it off the rim was impossible on his tire machine (pre-aluminum style). I'm just going to leave it on and shave the center a little, tire shop prices (even just for a balance) are starting to really hurt.
    Thanks again y'all.
    Ratch
    Welcome to America.
  13. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    If its a regular tire machine with the vertical shaft, use the bottom bead breaker by itself. You can flip the rim and tire over to break the other bead.
  14. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Yeah, that's the machine. We tried that, but the bottom breaker kept sliding up the rim, darn thing has no lip at the edge. We even tried the ancient manual machine before giving up. I was just bein' cheap, trying to move the spare onto the full-time slot. I figure I'll leave it alone as the spare and make it fit, since it looks like the only way to get it off will be take it to a shop with a newer machine (which'll cost me another pile), and I'd have to buy a new rim anyway. I got a new tire on the full-time rim, so I'll just leave that whole goof as a spare...
    Ratch
    Welcome to America.
  15. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Hey Ratch, that's exactly what I was talking about with the belt shifting/breaking in the tire...good to hear you're getting it fixed and it wasn't anything worse!
    Rene
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Oh yeah, tires can bite you. My grandfather has a visible DENT in his forehead from a truck tire that exploded in his face when he was young, working the coal mines of Scranton, PA. He lost like 5 days of his life-he was out cold for 2 days following, and doesn't remember the 2 days preceeding the explosion.
    I have a picture somewhere of a Navy aircraft mechanic who was literally torn in half by a sidewall blowout of an A-6 main tire. The inflator gauge was stuck at 275psi and wouldn't read further, the tire was supposed to get 350psi, and the regulator on the nitrogen cart was set at 600psi. Nasty sight...
    September 11, 2001--"A date which will live in infamy"
  17. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    tRusty, thanks, your reply to the bent axle post was the first thing I thought of when I saw the bump..
    Jarhead, 350PSI?????? Did they ever find the piece that hit the guy???? How thick are those tires???
    Ratch
    Welcome to America.
  18. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Hey Yorkin.. if ya still wanna try the tire machine, stabd on the pedal that runs the bead-breaker up...flip the breaker to the right on it's hinge, take out the spacer plate and flip the breaker back where it was. NOW that breaker will break your bead for you..also you don't want any tire lube on it when you're trying to break the bottom bead. Just watch it don't rip up the rim too much.
