Need help with tire wear
Discussion in 'The Garage' started by LlanoK5, Jul 28, 2003.
  1. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    Ok, here's the deal, I've got an 83 /forums/images/graemlins/k5.gif that the front tires have been leaning out at the top for some time now. I just replaced the ball joints (which was what my asking around said it would be), but my tires still lean. I need new tires, I'm just not wanting to buy any till I get the leaning problem fixed. My tierod is bent, and both ends need replacing, if that helps any. Could someone who knows more about the front end please help solve this problem. Thanks in advance.
    Kirk
  2. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    Check your wheel bearings for wear and correct adjustment
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Get a new tierod and set your toe-in to specs.
    This will more than likely cure your prob....
    Do they "appear" to be leaning in when looking at it from the front, or are your tires wearing on the outside??
    Rob
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Sounds like too much camber so they're riding on the outer edges. I just went thru a set of tires on my 88, same thing, Outer edge wore out and can see top of tires leaning out. The alignment spec calls for 1.5 degs positive. Im going to have mine set to .25 and see how it works.
  5. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    The tops of the tires are leaning out and wearing the outer edges.
    Where is the adjustment for the camber? I don't have a clue about aligning this thing or any other thing for that matter.
    Kirk
  6. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    They make speacial bushings to cure that problem. I just did a alingment today on a chevy truck that required the bushings. I can get the part # for you. It would be a napa part #.
  7. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    They also make a tapered shim for behind the spindle...but I've never gone out and bought a set so I can't help much more than that./forums/images/graemlins/crazy.gif
    You could also 'sky' the truck and hope the housing bends just enough.../forums/images/graemlins/grin.gif
    Rene
  8. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    I usually use Car Quest, I get better prices there, but I'm almost certain that I could get the Car Quest # to match if I had the napa #.
  9. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    That's a very good idea...on the other hand I'm trying to get my ride and handling better not tear the crap out of my truck. It probably would be fun though, if I can't get it fixed the old fashioned way I'll use your idea.
    Kirk
